sunywoman
Jan 05, 2017Follower
Password reset
Set Password Old Password Set Password Repeat New Password Enable Password Recovery Security Question #1*: Select a questionWhat was the name of the first NETGEAR...
DarrenM
Jan 09, 2017Sr. NETGEAR Moderator
Hello sunywoman
When doing the factory reset make sure you hold the reset button for at least 10 seconds to make sure it wipes all the old settings.
DarrenM
- altzarMar 18, 2017Aspirant
Why do I need to do a factory reset in order to change the password? What password should I use after the reset?
