mateosvw's avatar
mateosvw
Follower
Oct 14, 2016
Performance issue
Greetings,
I have recently experienced noticeable lag and slowdown in my wifi, and for the first time noticed a message stating Performance Recommendation pop up next to my home wifi network (viewed on my cell phone).  I have a N600/WNDR3700 router, along with a NETGEAR DOCSIS 3.0 High Speed Cable Modem Certified for Comcast.  I do not see any updates for my router, and wonder if it's simply time to replace it.  Regarding the dual-band signaling feature (2.4 GHz and 5 GHz), I only use the former as the 5ghz option always has a weaker signal.  My firmware is V1.0.7.98NA, and My OS is Win7 32Bit,
I have a NETGEAR N300 Wi-Fi Range Extender and use that upstairs in my home, but this hasn't caused a problem in the past.
My Comcast Account Internet plan is Performance Pro, calling for the following speeds:
Download Speed: 50Mbps*
Upload Speed: 5Mbps
Here is a recent Comcast Speed Test: Download speed of 27 Mbps, Upload of 5Mbps
Any thoughts about what could be going on?
Thanks
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mateosvw
    It could be some wifi interference I would try logging into your router and go to the wireless settings and try to change the wireless channel.
    DarrenM
