pquihuis
Jul 29, 2016Aspirant
Performance issues with CM500 and Time Warner
My internet continues to drop and/or my speeds come down to a crawl below 1MB. I have made multiple calls for service, with technicians dispatched to home to find nothing with the signal and pointin...
Doc_Sis
Jul 31, 2016Aspirant
Same Issue:
| Firmware Version V1.01.04 |
And just yesterday I'm starting to have odd slowdowns and DNS resolution issues!
DarrenM
Aug 01, 2016Sr. NETGEAR Moderator
Hello pquihuis
You log shows T3 timeouts which means you are getting noise on the lines I would call the ISP and have them send a tech out to check the lines see if they can resolve the issue. Below I left a description of a T3 timeout.
"The cable modem has sent 16 Ranging Request (RNG-REQ) messages without receiving a Ranging Response (RNG-RSP) message in reply from the CMTS. The cable modem is therefore resetting its cable interface and restarting the registration process. This typically is caused by noise on the upstream that causes the loss of MAC-layer messages. Noise could also raise the signal-to-noise ratio (SNR) on the upstream to a point where the cable modem’s power level is insufficient to transmit any messages. If the cable modem cannot raise its upstream transmit power level to a level that allows successful communication within the maximum timeout period, it resets its cable interface and restarts the registration process. This error message is DOCSIS event message is R03.0, Ranging Request."
DarrenM
- pquihuisAug 01, 2016Aspirant
Thanks Darren,
I will reach out to my ISP. I also see that Channel 2 on the Upstream is showing "Not Locked and Power shows 0.0dBmV", is this also an issue?
Upstream Bonded Channels (Partial Service)
Channel
Lock Status
US Channel Type
Channel ID
Symbol Rate
Frequency
Power
1
Locked
ATDMA
3
5120 Ksym/sec
30600000 Hz
39.8 dBmV
2
Not Locked
Unknown
2
0 Ksym/sec
24200000 Hz
0.0 dBmV
Regards, Phil...
- cylSep 12, 2016Aspirant
I'm embarrassed by my earlier post. I was looking at the long Netgear device. My CM500 does have the correct firmware version to work with TWC.
But my access points and routers aren't able to get IP addresses and DNS from the network. Do any of these logs tell me what the problem might be?
Time Priority Description 1970-1-1, 00:09:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-6, 16:53:48 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-6, 22:25:21 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:20 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-8, 04:22:45 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:20 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-9, 02:08:58 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-10, 16:30:36 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-10, 21:21:07 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-10, 22:14:24 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-10, 23:03:58 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:26 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 2016-9-10, 23:06:00 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-11, 23:43:55 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2016-9-11, 23:56:25 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:27 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 2016-9-12, 00:28:34 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:26 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 2016-9-12, 01:39:07 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:28 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:31 Notice (6) Honoring MDD; IP provisioning mode = IPv4 1970-1-1, 00:00:33 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 2016-9-13, 05:03:02 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.1;CM-VER=3.0; 2016-9-13, 05:03:02 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.1;CM-VER=3.0; 2016-9-13, 05:03:09 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 2016-9-13, 05:03:11 Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 2016-9-13, 05:03:24 Warning (5) ToD request sent - No Response received;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.0;CM-VER=3.0; 2016-9-13, 05:03:25 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.1;CM-VER=3.0; 2016-9-13, 05:03:25 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=2c:30:33:1a:42:b0;CMTS-MAC=00:01:5c:64:de:5d;CM-QOS=1.1;CM-VER=3.0; - DarrenMSep 14, 2016Sr. NETGEAR Moderator
Hello cyl
You do have alot of T3 timeouts which is a issue with the cable signal I would suggest having a your ISP send out a tech to check your lines and signal strength.
DarrenM
