pquihuis
Jul 29, 2016Aspirant
Performance issues with CM500 and Time Warner
My internet continues to drop and/or my speeds come down to a crawl below 1MB. I have made multiple calls for service, with technicians dispatched to home to find nothing with the signal and pointin...
pquihuis
Aug 01, 2016Aspirant
Thanks Darren,
I will reach out to my ISP. I also see that Channel 2 on the Upstream is showing "Not Locked and Power shows 0.0dBmV", is this also an issue?
Upstream Bonded Channels (Partial Service) | |||||||||||||||||||||
Regards, Phil...
pquihuis
Also, should the Uncorrectables be zero, as last week they were in the 5 digit number range?
Phil...
- DarrenMAug 02, 2016Sr. NETGEAR Moderator
Hello pquihuis
You will have to ask the ISP about that and the uncorrectables being a low number is fine.
DarrenM
- pquihuisAug 06, 2016Aspirant
I have followed up with Time Warner and their L3, but they are continuing to point the issue to my Netgear CM500 modem. Even after sharing my event log highlighting the errors, they continue to claim that all signal levels are within specification. To get past the finger pointing, I will rent their modem to assess if my problems continue. I'll keep you posted.
Regards, Phil...
- pquihuisSep 12, 2016Aspirant
I have since then swapped out my CM500 with Time Warner's Arris Cable modem to see if my issues remain. It has now been 1 month and my daily speed issues have gone away. I will send my Netgear CM500 Cable Modem back for repair and try again once it returns.
Phil....
