Infosec_stoic
Mar 22, 2021Aspirant
Ping Spikes and dropped packets
Hey guys! So this started about 4-5 days ago where my nighthawk C7000V2 (Firmware V1.03.01) would intermittently have massive packet spikes and dropped packets. This isn't just with gaming . Since I...
Mar 23, 2021Guru - Experienced User
do you have a screen snip of the cable connections page and event logs?
that helps us check the connection back to the isp.
they're great at saying "its not our line".
And it might not be.
Check you coax line for kinks, bad/old/loose connectors, moisture in the line, etc.
Also, if you have any splitters, amplifiers, or attenuators, remove them from the line. preferable, directly connect the c7000 to where the coax comes into the home to prevent the wiring in the home from being the issue.
Infosec_stoic
Mar 23, 2021Aspirant
Sorry no idea why It didn't post the screenshot.
- plemansMar 24, 2021Guru - Experienced User
Your power levels are out of spec (to high) and you have errors in your line.
check your line. You might actually need a signal attenuator or splitter in line to drop power to get it in spec .
Otherwise your isp will need to check the line
- Infosec_stoicMar 24, 2021Aspirant
Awesome!
Out of curiosity, could you help me understand how you came to that conclusion? What are the power levels normally supposed to be at? How where you able to verify the errors?
Sorry for all the questions :) Networking isnt a strongpoint of mine, but I aim to get better!
Thanks again for the help!
Optimal power levels should be from -7.5dbmv to 7.5dbmv. You're quite high.
Also, the correctables/uncorrectables are the errors.
Plus you have channels that aren't locking. So it tends to indicate issues. with your power levels high, that's where I'd start.
