Infosec_stoic
Mar 22, 2021Aspirant
Ping Spikes and dropped packets
Hey guys! So this started about 4-5 days ago where my nighthawk C7000V2 (Firmware V1.03.01) would intermittently have massive packet spikes and dropped packets. This isn't just with gaming . Since I...
Infosec_stoic
Mar 23, 2021Aspirant
Sorry no idea why It didn't post the screenshot.
Mar 24, 2021Guru - Experienced User
Your power levels are out of spec (to high) and you have errors in your line.
check your line. You might actually need a signal attenuator or splitter in line to drop power to get it in spec .
Otherwise your isp will need to check the line
- Infosec_stoicMar 24, 2021Aspirant
Awesome!
Out of curiosity, could you help me understand how you came to that conclusion? What are the power levels normally supposed to be at? How where you able to verify the errors?
Sorry for all the questions :) Networking isnt a strongpoint of mine, but I aim to get better!
Thanks again for the help!
- plemansMar 24, 2021Guru - Experienced User
Optimal power levels should be from -7.5dbmv to 7.5dbmv. You're quite high.
Also, the correctables/uncorrectables are the errors.
Plus you have channels that aren't locking. So it tends to indicate issues. with your power levels high, that's where I'd start.
