afitz485's avatar
Aug 10, 2022
placing CAX80 in bridge mode
How do I place my CAX80 in bridge mode, so it behaves like a switch, not a router. I will use my enterprise router downstream.
I checked the Netgear user manual but no help there.
Thanks!
  • plemans's avatar
    You can put it modem only mode but then most ISP's only support 1 connected device to it.
    Or you can leave it in router mode and simply put the enterprise routers ip address into its dmz.
    • Pookas's avatar
      Pookas
      This is exactly what I would like as well. Does not necessarily have to be CAX80. My ISP does allow multiple external ipv4 but I am struggling to find a modem that will provide... have found any approaches?
      • afitz485's avatar
        afitz485
        Tutor
        Under the Advanced settings on my CAX80, there is an option for Router Mode (On Off). Once I select the Off option, my modem appears to be in bridge mode.
