Nico78's avatar
Nico78
Please, ethernet cable for model XAVT5602 ? thanks
Hi, my ethernet cable no longer holds, it broke at the end, where can I buy this cable again, I have the model XAVT5602, thank you.
  • > my ethernet cable no longer holds, it broke at the end, where can I
    > buy this cable again, I have the model XAVT5602, [...]
       There's nothing special about the Ethernet cables which came with
    those devices.  Practically any similar cable should work.  I'd look for
    "Cat 5e" or better.  Choose a color and length which you find suitable.
    • Nico78's avatar
      Nico78
      Hello, thank you very much, what brand / model you would advise me please, thank you again.
      • antinode's avatar
        antinode
        Guru
        > [...] what brand / model you would advise me please, [...]
           It really makes very little difference.
