zunka
Dec 07, 2024Guide
Please Help CM1200 Modem Speed Slowdown require constant rebooting
For the last three weeks, my internet speed drops drastically from over 950 Mbps to 30 MBps. Rebooting the modem restores the speed but lasts only for a day or two. There are many threads on si...
- Dec 19, 2024
Ok, next time please post the cable connections and event logs from the CM modem so we can help check and ensure problems seen on a modem may not be modem related, may ISP signal related. All things needs to be check upstream first before claiming the modem is the problem.
Enjoy.
Dec 08, 2024Guru - Experienced User
You have a ton of errors in your line. A ton.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Try that first and if it doesn't help, then you do need to contact the isp
- KitsapDec 08, 2024Master
plemans wrote:You have a ton of errors in your line. A ton.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.Try that first and if it doesn't help, then you do need to contact the isp
Below is a good reference site to supplement plemans recommendations. Duckware is technically very competent.
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- zunkaDec 08, 2024Guide
Pelman & Kitsap
Thank you for your suggestions and the link to the website.
It looks like the connector for the cable from the pole to the house has some sort of water damage. It matches, at least to me, the pictures posted on the duckware website.
Cable inside the house seems to be fine. I don't have any amplifiers. Only one splitter for a cable to my TV and Modem. Removing that didn't seem to have made any difference.
I need to call my ISP to check it out. Optimum service is not good (that is an understatement). Will keep you guys posted after couple of days.
Thank you.
- zunkaDec 14, 2024Guide
The ISP Technician replaced all outside connectors (i.e. on the pole, outside the house). He also replaced the splitter and wire inside the house up to the Modem.
On his diagnostic device (don't know what it is called), he showed me the signal strength was good, stable and without any noise.
He had another device that was showing diagnostics after connecting the modem. It was failing a test. The upstream bonded channel power was too high (about 53 dBmV).
He concluded that most likely modem is faulty because we had just replaced the wires, spitter and checked the signal quality in the coaxial cable.
Want to get your opinion before I replace the modem.
Please let me know your thoughts.
