zunka's avatar
zunka
Guide
Dec 07, 2024
Please Help CM1200 Modem Speed Slowdown require constant rebooting
For the last three weeks, my internet speed drops drastically from over 950 Mbps to 30 MBps.  Rebooting the modem restores the speed but lasts only for a day or two.    There are many threads on si...
  • FURRYe38's avatar
    Ok, next time please post the cable connections and event logs from the CM modem so we can help check and ensure problems seen on a modem may not be modem related, may ISP signal related. All things needs to be check upstream first before claiming the modem is the problem.
    Enjoy.
