zunka
Dec 07, 2024Guide
Please Help CM1200 Modem Speed Slowdown require constant rebooting
For the last three weeks, my internet speed drops drastically from over 950 Mbps to 30 MBps. Rebooting the modem restores the speed but lasts only for a day or two. There are many threads on si...
- Dec 19, 2024
Ok, next time please post the cable connections and event logs from the CM modem so we can help check and ensure problems seen on a modem may not be modem related, may ISP signal related. All things needs to be check upstream first before claiming the modem is the problem.
Enjoy.
zunka
Dec 19, 2024Guide
I purchased new ARRIS S33 modem to replace my NetGear CM1200. It is working good so far (been only a day). Keeping my fingers crossed.
All the Downstream and Upstream bonded channels power levels seem to be within the range. No critical errors or uncorrectables so far. So, it looks like my old Netgear modem was the problem.
BTW, my ISP is Optimum in NJ
Thank you all for your help and guidance.
Dec 19, 2024Guru - Experienced User
Enjoy.
