DarkMage's avatar
DarkMage
Follower
Jul 21, 2023
Port Aggregation for CAX30
Hello:
All the questions below are based on wired, ethernet connections from a Netgear CAX30 Modem/Router to a desktop computer.
-Is Port Aggregation something I can use to increase the download speeds in my computer by using two ports, similar to Windows "Bridge Connections" feature?
-If both methods work the same, which one is the preferred method, Windows Bridge Connections or Modem/Router Port Aggregation?
-If Port Aggregation can be setup to increase the download speeds to my computer, how do I do this using a Netgear CAX30 Modem Router?
Thank you.
