reynolds087
Sep 04, 2016Follower
Port Forward issues
I'm trying to use an application called Jacktrip with a friend of mine. He has an N450 WiFi cable modem and I set up port forwarding for him because the app uses port 4464 UDP. I'm not sure what is c...
DarrenM
Sep 07, 2016Sr. NETGEAR Moderator
Hello reynolds087
Since you said this IP is not pingable have you tried to run a trace route to see if the connection drops off before getting to his network?
DarrenM
