VSCurtis
May 18, 2018Aspirant
Port Forwarding For Home Based VPN Server
Hi Guys,
I am attempting to create a home based VPN Sever. I have completed the basic configuration necessary for the server itself and am now attempting to complete the necessary port forwarding s...
antinode
May 18, 2018Guru
> [...] I'm unsure what to do with regard to the dynamic IP address of
> the VPN Server as this a home network and the machine's IP Address will
> change every time it's shut down and/or rebooted. I know there is a way
> to handle this as part of the port forwarding but as I said I'm a little
> unclear on the process. [...]
ADVANCED > Setup > LAN Setup : Address Reservation
It's not really "part of the port forwarding", but, as you've
noticed, the target/server IP address appears in your port-forwarding
rule, so that server must have a fixed address. Address reservation
tells the router's DHCP server to give that server the same IP address
every time it asks. (The other way would be to assign a static address
to the server (and not use DHCP for it), but using a reserved (dynamic)
address lets you leave the server IP configuration on "automatic", and
let the router ensure that it always gets the desired address.)
Either way, it's generally safer to shrink the DHCP address pool
(Starting IP Address, Ending IP Address) from the default of ".2" -
".254" (every available address) to something less, like, say, ".2" -
".199"), and then use the ".200" - .254" range for your reserved or
static addresses. That way you can be sure that (no matter how stupid
it might be) the DHCP server won't accidentally issue any reserved or
static address to some other device.
VSCurtis
Thanks for your input regarding the address reservation. This information will be helpful in resolving that part of the task. I appreciate the assist. My IT training is software oriented with only basic training in areas such as networking. Hopefully someone will respond concering the port forwarding issue.
- antinodeMay 19, 2018Guru
> [...] Hopefully someone will respond concering the port forwarding
> issue.
What is "the port forwarding issue"?
> I am attempting to create a home based VPN Se[r]ver. [...]
Not a very detailed description of anything.
> [...] attempting to complete the necessary port forwarding steps for
> my router, [...]
What are those "necessary port forwarding steps"? Are you following
some set of (invisible?) instructions?- VSCurtisMay 19, 2018Aspirant
Yes, I am following instructions from a posting on the internet. I've read several articles on the subject and they all state that port forwarding is part of the process. As I stated my networking skills are limited and I don't quite understand the information concerning port forwarding.
> [...] I am following instructions from a posting on the internet.
With my weak psychic powers, I can't see what you're reading.
> [...] I don't quite understand the information concerning port
> forwarding.
Similarly, I can't see this "information", or guess what about it is
mystifying. This new Inter-Web thing has some potential to provide
information on many topics. For example:
https://en.wikipedia.org/wiki/Port_forwarding
Less diffuse questions could get more specific answers, but "VPN
Server" is a bit too vague to make a specific answer practical.
