Timebomb41
Aug 12, 2015Aspirant
Port forwarding isn't working
So I don't know if this is in the right place but, i've been trying to portforward my N300 WiFi Cable Modem Router Model C3000 and when I check to see if the ports are open it says they are not open ...
Timebomb41
Aug 13, 2015Aspirant
That did not work is there anything else I could try to get it to work?
DarrenM
Aug 14, 2015Sr. NETGEAR Moderator
You could put the device in the DMZ and see if that works. I did also find a good website that has a list of all the things that could be causing the issues with the port fowarding take a look at this.
http://www.pcwintech.com/common-problems-fixes-port-forwarding
DarrenM
