LiamR16
Sep 07, 2018Aspirant
Port forwarding issues
Hi, I'm trying to forward some ports on from my router to my PC but am having quite a bit of trouble.
As you can see in the screenshot below. I have added both of the required ports to allow co...
LiamR16
Sep 08, 2018Aspirant
> What have you done to ensure that it always has the address which appears in the port-forwarding rule?
I've tried going into the ipv4 address settings but whenever I assign a static IP address I lose network connectivity.
>Are you specifying the right external/public IP address for testing? Is that the WAN/Internet IP address of the router?
The IP address being used to test is that of my router.
antinode
Sep 08, 2018Guru
I don't know what that means. Which "the ipv4 address settings" do
you mean? "whenever [you] assign a static IP address" to what? Are you
fiddling with the settings on your computer (in secret ways)? I'd
expect there to be an Address Reservation table under some location like
ADVANCED > Setup > LAN Setup, and reserving an address there might be
simpler/safer than trying to assign a static address on the computer
itself.
Each interface of your router has its own IP address. The LAN
interface has one, and the WAN/Internet interface has another one. What
is your router's WAN/Internet IP address? (The first two octets of what
should be your public IP address ("a.b" out of "a.b.c.d") will do, if
you don't want to reveal the whole thing.)
What is the target server ("Internal") IP Address in your
port-forwarding rules?
> [...] What is the IP address of that target server? [...]
Still wondering.
> Is the server program running on the target server system?
Still wondering.
- LiamR16Sep 08, 2018Aspirant
I've gone into the Netgear genie and reserved the IP address for my device - 192.168.0.35
The public IP of my router beings with 58.107
Not sure what you mean by "Server program"
- antinodeSep 09, 2018Guru
What is your "my device"? And is it now at that address?
Ok.
Still wondering.
This whole Q&A thing works better if all the questions get answered
the first time they're asked.
When a message from the outside world arrives at (the WAN/Internet
interface of) your router, a port forwarding rule tells the router to
forward that message to a computer at some particular LAN IP address and
port number. What happens to that message when it arrives at that
computer? Some (server) program must be running on that computer which
is listening at that port number, or else that message will be ignored.
If you tell the post office to forward your mail to a vacant lot,
then it won't get delivered.
> [...] I'm trying to forward some ports on from my router to my PC
Why?- LiamR16Sep 09, 2018Aspirant> What is your "my device"? And is it now at that address?
Windows 10 PC, yes
192.168.0.35
The ports are to be used by the application 'Destiny 2'.
Based on the developers recommendations the two ports from the screenshot should be forwarded to the device running the application.
