CoffeeOrTea
May 14, 2020Follower
Port Forwarding Not Visible
Hello, I am experiencing an issue where my NAT type is set to strict on my new computer. I tried accessing the router to set up a port forward but the option to do so doesn't pop up on my menu in...
antinode
May 19, 2020Guru
> Model: C3700|N600 Cable Gateway Docsis 3.0
Is that accurate? C3700 or C3700v2? Look for "Model" on the product
label.
> [...] I tried accessing the router [...]
"accessing the router" how, exactly? Some app or other? Web
browser? Other?
> [...] to set up a port forward but the option to do so doesn't pop up
> on my menu in the genie.
Huh? "pop up"? It won't look for you; you might need to look for
it.
_Which_ "the genie"? Ever helpful, Netgear uses the name "Genie" for
more than one thing. Netgear routers have a web-browser interface
called "Genie", and Netgear offers application programs for various
computers/tablets/phones, which are also called "Genie". Which "the
genie"?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "port forwarding"?
> [...] Any reason this might be happening?
Any reason _what_ might be happening?
