jalan
Oct 17, 2017Follower
Port forwarding problem
Firmware Version V1.01.15, Windows 7. I set up some ports to be forwarded. Set them up properly but they are not working and on checking on canyouseeme, nothing is showing as forwarded. Turned off ...
antinode
Oct 17, 2017Guru
> Set them up properly [...]
Evidence? Actual rules?
> Correct Internal IP Address is selected.
Evidence? How have you fixed that IP address? (Reserved? Static?)
Are there any server programs running on that system which are listening
on the designated ports? Can they be reached from the LAN on those
ports at that system's LAN address?
> Is there some setting on the Netgear I may be missing?
It's hard to tell, knowing approximately nothing about what you
actually did.
