Gamedroid
Jan 01, 2017Tutor
port forwarding with an internet phone
ive been trying to port forward to setup some game servers but ran into a problem when i might have three seprate routers. using a check multiple routers tool i downloaded i discovered i have two...
Gamedroid
Jan 02, 2017Tutor
let me add some screen caps to make this a bit more clear
this is the two supposed routers on my network
the being a netgear router and the second being an xfinity/comcast one
the xfinity router also shows another device connected, connecting to it shows this
this is also somehow the domain server for the netgear router
i should also point out the xfinity routers port forward page has the servers ip mostly grayed out
- DarrenMJan 04, 2017Sr. NETGEAR Moderator
Hello Gamedroid
You should only have 1 router handling the DHCP so you will either need to bridge the modem or turn the other routers into access points so then you will be able to port forward your devices.
DarrenM
