sarantube's avatar
sarantube
Follower
Sep 26, 2017
Port Forwarding
I am trying to connect my Lorex Security cameras for remote viewing.  The installation guide says to port forward the Client Port, Http Port and Mobile port.  I am using the netgear genie application but cannot find where to check current ports or set up special ports for my camera system
1 Reply
  • > [...] The installation guide says [...]
       Are you offering any hints as to where you found this "The
    installation guide" so that the rest of us might look at it, too?
    > [...] to port forward the Client Port, Http Port and Mobile port.
       Do you have any numbers for these ports?
    > I am using the netgear genie application [...]
       On what?  I've never used it.  Have you looked at the Web interface
    to the router?  I'd guess a path like ADVANCED > Advanved Setup > Port
    Forwarding / Port Triggering.
