Rsteger
Dec 06, 2020Follower
Ports 2,3,and 4 on CM1200
I'm new here, so maybe someone can help me understand the purpose of ports 2,3,& 4 on the CM1200. I had hoped to use these ports to send a signal directly to my TV (using Apple TV) and a LAN switch ...
- Dec 06, 2020
A modem isn't the correct devices if you're wanting multiple devices connected. A modem/router is the correct device.
Or go modem----router----switch.
The cm1200 confuses a lot of people and there isn't good education done on it from netgear or isp's. Half the problem is that there are ISP's that support multiple public ip addresses. in those cases you can hook multiple devices to it. But those ISP's are rare. the big 3 (comcast, cox, spectrum) don't support more than 1 public ip address unless you pay for it or have a business class line.
Dec 06, 2020Guru - Experienced User
Ports 2,3, and 4 are for ISP assigned WAN IP addresses. So if your ISP supportings having more than on WAN IP address going to the modem, then these ports would be use for this. So you could have up to 4 external wifi routers connected to the one modem.
Check with the ISP for additional information regarding having more than 1 WAN IP address. Some ISPs may not support this.
The CM series modems do not have a built in router. These are modems only.
