multicm
Nov 28, 2016Aspirant
Ports closed after Port Forwarding
When I forward a set of ports they remain closed and my server does not work through it, as can be seen from the following pictures: Port Forwarding: Assign port: Test Port (Close...
DarrenM
Dec 08, 2016Sr. NETGEAR Moderator
Hello multicam
On the AP do you have it set to a specific AP mode and DHCP disabled?
DarrenM
multicm
Dec 12, 2016Aspirant
Hello DarrenM, thanks for the help.
On the AP, DHCP mode is not disabled, but that doesn't matter as the DHCP server on the AP is designed to assign addresses in the 192.168.2.xxx subnet, while the main modem is in the 192.168.0.xxx subnet. My PC is in modem's subnet. Also, when I go into my AP under "Connected Devices" it doesn't show any because it is not assigning IPs, instead it is forwarding all devices straight to the modem, like an AP is suppose to. Even when I use a Wi-Fi device being held right next to the AP (Very high signal strength) it is given a 192.168.0.xxx address
