multicm
Nov 28, 2016Aspirant
Ports closed after Port Forwarding
When I forward a set of ports they remain closed and my server does not work through it, as can be seen from the following pictures: Port Forwarding: Assign port: Test Port (Close...
multicm
Dec 18, 2016Aspirant
Okay so i went ahead and removed the router that was acting as an AP just Incase. I added a switch instead. So the switch has zero affect on Port Forwarding. Nothing has changed.... Still not port forwarding...
