saqer
Jul 12, 2022Aspirant
Possible hardware malfunction with cm1100
Power went out briefly and came back on this morning. Internet did not kick back on. Check router and it’s only displaying 2 Amber LED’s (LAN). Power button and all other LED’s are off. I attempted to...
- Jul 12, 2022
I would guess so. Modem seems non recoverable.
Will need to be replaced I guess.
saqer
That's correct, with only power connected I'm not getting anything. Tried a different power supply - same thing - only getting two bottom solid, amber LED's. Tried to a different ethernet cable - also no go. Is it possible for power spikes in the COAX line to have fried the electronics?
Edit: resetting physical power button does nothing either.
Jul 12, 2022Guru - Experienced User
