mrd1's avatar
mrd1
power adapter for c7000vs - looking for a lower profile adapter
The power adapter that comes with this product is tall profile and sticks out from the wall socket 2.75 inches.  I was wondering if a lower profile adapter is available that would be compatible with ...
  • FURRYe38's avatar
    Dec 30, 2023
    If you can find one that has same voltage and amp specs and same plug in connector. Otherwise, easier to find a flush wall plug in extender cable and just plug that in to the wall then plug the other end into the power plug brick for the modem.
