3fun
Apr 21, 2022Aspirant
Power adapter for CM1000, what is the model number?
Is there a nice soul who is willing to unplug their CM1000 power supply from the wall and share its model number? It should look something similar to this or at least in similar format (this is info...
- Apr 23, 2022
Most power adapters for NG use same plug for CM modems.
Here is my CM1100 info:
Fits my CM1200 as well.
Apr 22, 2022Guru - Experienced User
As long as the voltage and amps are same and find the same plug that fits the modem, you'll be fine. Most of the CM series modems all use the same plug end:
3fun
Apr 22, 2022Aspirant
Thanks for trying to help. Buying power adapters online until I receive one that fits the size is a lottery not a real solution.
Voltage and amperage are known. It is the size of the connector barrel that is in question and the only way to know upfront is to have the model #.
- FURRYe38Apr 23, 2022Guru - Experienced User
- 3funApr 24, 2022Aspirant
Thank you very much, this is exactly what I needed.
- michaelkenwardApr 24, 2022Guru - Experienced User
An alternative is to buy an adapter with a set of tips. Widely available.
Generic adapter
