GreenGMC
Dec 23, 2022Aspirant
Power Blip Factory Reset Modem/Router Nighthawk AX6 CAX30
Had a power blip at my house. My modem/WiFi router reset to factory settings. Nighthawk app is useless and won’t connect. Now I have to reset the modem/router and dozens of devices and connected plugs...
GreenGMC
Feb 02, 2023Aspirant
Power went off for five minutes overnight, and this has happened again. At first some mobile devices could connect to the WiFi and had sporadic internet connection. Now no mobile devices or IoT devices can connect to the router, and even the hardwired Arlo/NetGear camera router that is hardwired to the NetGear router isn’t connecting to the internet. I’ll look into backing up my configuration, but I’ll be looking for a different brand router.
michaelkenward
Feb 03, 2023Guru - Experienced User
The usual reply when this happens is to ensure that you reboot the whole network in the correct order. But that is kind of difficult when you have a combined modem/router.
Bit late to back up the configuration. You should have a copy there of that already so that you can restore the configuration after this happens.
As to another device, experienced users prefer separate modems and routers. CAX devices are better than some with their separate router firmware, but it still doesn't have the flexibility of a modem followed by a router, which gives a much bigger choice of options.
