winthwe03
Jan 24, 2022Aspirant
Power flashing green, and others flashing orange
I woke up today and I am having the same exact probelm reported below. Previous Problem Link Are there any solutions for this issue? I have contacted support and sent provate messages to moderato...
winthwe03
Jan 25, 2022Aspirant
It does the same thing.
Jan 25, 2022Guru - Experienced User
If its doing the same thing without a coax plugged in, then it sounds like a hardware failure and you'd need to contact support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
