Camrich22
Mar 16, 2024Aspirant
Power outage caused loss of internet, now it says my security answers are not right...but they are?
Mar 17, 2024Guru - Experienced User
could be the router/modem or whatever you have factory reset from the power outage/surge. You don't tell us what device you have.
Camrich22
Mar 17, 2024Aspirant
I try to sign on and they ask for the serial #, and I put it in and it says that's not the right number. (10 times) But it is the only device I have hooked to my computer. Also, like I said, it won't accept my security answers.
- plemansMar 17, 2024Guru - Experienced User
have you tried a factory reset?
If you reset it, the default password should either be password or on the bottom of it.
we still don't know what device you have
