nealct56
Jul 20, 2022Aspirant
Power yet no connection
Nighthawk AC1900 WiFi Cable Modem Router Cable is connected; Power Cord connected Solid white constant light on top side reset button, and Tel 1 LED, Tel 2 LED, and Battery LED. All other LED lights...
nealct56
Thanks! It is a model C7100V
The top constant on button is the PUSH ‘N’ CONNECT—Easy push button WiFi connections (WPS)
I held that button for 10 secs with power plugged in and cable disconnected. No change. Try small recessed reset next?
Jul 20, 2022Guru - Experienced User
Yes the small recessed reset button is the one to push and hold.
The lights should change when held long enough. Then you'll need to go through the install procedure.
C7100V | Product | Support | NETGEAR
- nealct56Jul 20, 2022AspirantThanks. Pressed the reset button for 15 seconds with coax disconnected. Not the Power, DS/US, and Online buttons are faintly blinking. The 2.4 and 5 GHz buttons are faint and constant.
The top button is still on constant white light.
Will connect coax and attempt a reinstall.
The top
