DCHEW
Apr 03, 2019Follower
Printing Issue NIGHTHAWK X4S DOCSIS® 3.1 C7800
I have a NIGHTHAWK X4S DOCSIS® 3.1 C7800 Cable Modem. I have an HP Color LaserJet CM1312nfi MFP Printer. I'm using a MacBook Pro running Mojave 10.14.4. Printer has the most updated firmware. Mac...
JoseAndres041
Apr 24, 2019Luminary
Can you go to Printers and Scanners and check if the printer is using the correct IP Address? Go to IP and you should see Protocol there. Check if the IP address is the IP adddress of your printer.
