BodhiH
Apr 09, 2018Follower
Printing using Netgear ReadySHARE Print function is not working.
Hello, I'm using a Nighthawk C7000-100NAS Modem/Wireless Router with my MacBook Pro (OSX High Sierra). I have been trying for some time to connect my HP Deskjet 2050 to the router via the USB ca...
michaelkenward
Apr 10, 2018Guru - Experienced User
BodhiH wrote:
Hello,
So why does your footer say R7000?
Probably because you posted in the routers section of this forum rather than cable modems.
Cable Modems & Routers - NETGEAR Communities
You might get better answers there.
As to the firmware:
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
