socherl
Mar 29, 2020Tutor
Priority devices on AC1900 (model C7100V) with Xfinity in response to COVID-19
I have an AC1900 (model C7100V) that I use with Comcast Xfinity. Given the switch to more telecommuting and remote learning with COVID-19 using Microsoft Teams and other tools for voice, video, and ...
socherl
Mar 29, 2020Tutor
Thanks for feedback. When I purchased the AC1900 I was trying to avoid additional devices/break points. Had I realized Netgear and Comcast had so many challenges working together, I would have purchased the Arris T25 and separate WiFi gateway that could do QoS. If I continue to have issues with the AC1900, may just write it off and purchase two devices anyway. Current model with with Comcast Firmware Version V2.01.42 is really flaky.
Mar 29, 2020Guru - Experienced User
It might be your connection.
do you have a screen snip of your modem connection back to the ISP?
If you have any splitter, attenuators, amplifiers in the coax line, remove them.
- socherlMar 30, 2020Tutor
Only splitter was replaced by Comcast when installing and they put in an amplifier. Works fine most of the time with decent performance, but every three or four weeks CMTS and modem get out of sync and requires reboot (often multiple times) of the Nighthawk.
- plemansMar 30, 2020Guru - Experienced User
amplifiers are great at causing issues. Either because they add to much power, filter out the upstream, or inject interference.
do you NEED the amplifier is the question.
Take a screen snip of themodem connections page before and after the amplifier.
Also, if you need the amplifier to boost for watching tv, put a single splitter where the coax enters the home. send one leg to the modem and the other to the ampifier and then feed the rest of the house off that one. If you can possible avoid it, you don't want the amplifier in line to the modem.
Very good advice. Not physically at house now but will look at positioning of amplifiers and splitters. Thanks.
