lamannashp
Jan 25, 2021Aspirant
Problem with new modem CM1200
My modem is CM1200. My ISP is Suddenlink. Two speeds with highest being 5K. Router is Nighthawk AC1900. Modem constantly going down. Did i set it wrong? Included file has connection and event log.
Jan 25, 2021Guru - Experienced User
You don't have errors in your cable connections page but your power levels are a bit interesting. You should only have around 3.5dbmv between channels and you're going from a -4.3dbmv to a +2.9. roughly a 7.2dbmv difference. not horrible but not great.
and you're logs are a bit all over the place.
I'd check your line for issues with splitters, amplifiers, or attenuators. remove them if you have them.
check for damage to the line like kinks, loose/old/cheap/bad connectors.
lamannashp
Jan 26, 2021Aspirant
Apparently, there is an Amplifier as shown by the photos. But Im not sure where all the outputs go to. I know one goes to the telephone included in the service. Should I buy a new amplifier and just transfer all the cables to the new amplifier??
