Tman77
Jun 27, 2022Tutor
problems connecting my cellphone to my CM600 cable modem
Suddely I can no longer access my network with my cellphone. I get a pop up that says “This device is blocked by Access Control in the router”. However I can still access my “guest network”. Every ot...
- Jun 27, 2022
Yes its Model CAX30, I appreciate your help. I’ll give it a try
Jun 27, 2022Guru - Experienced User
The CM600 is a modem only device and has no routing/access control.
What router do you have?
Have you gone into access control and set your phone as allowed?
