DennisM23
Oct 19, 2015Aspirant
Problems connecting to comcast
So I recently got a problem with my Netgear CG3000Dv2 N450 Router. I've had the router for over 3 months now and haven't had a problem with it until 3 days ago. The router works and all the lights ar...
Babylon5
Oct 20, 2015NETGEAR Employee Retired
Since you specifically mentioned wireless connections does that mean that you don’t have issues with wired connections to the router?
- DennisM23Oct 20, 2015Aspirant
Wired connection doesn't work either.
- vkdeltaOct 22, 2015NETGEAR Employee Retired
1. Clear your browser cache
2. Activate the router one time and see if re-appears.
3. Call comcast and provide the MAC to make sure MAC is actually on your account and you dont have 2 modems online with same account.
