hugsss_2000
Aug 18, 2022Aspirant
problems updating firmware C7800v2
I have the nighthawk c7800v2. I have had it since February 2021. My isp is mediacom. I have connection issues ie get dropped from the internet but able to get right back on easily. a tech came to the...
hugsss_2000
can you direct me where to find the connection status page?
Aug 18, 2022Guru - Experienced User
1. Launch a web browser from a computer or mobile device that is connected to the
modem router network.
2. Enter http://routerlogin.net or http://192.168.0.1.
A login window opens.
3. Enter the modem router user name and password.
The user name is admin. The default password is password. The user name and
password are case-sensitive.
The BASIC Home page displays.
4. Select Cable Connection.
- hugsss_2000Aug 18, 2022Aspirant
- FURRYe38Aug 18, 2022Guru - Experienced User
Power levels are too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
You have too much Correct and Un-Correctables that should be mostly zeros. Need to check the coax cable line for kinks, fittings and any splitters.
Not all channels are locked in. This depends on your ISP speed package. What Speeds UP and Down do you pay for?
Check the events log as well If any Criticals or Errors are seen there, the ISP needs to review them and help resolve them.
