pablocarc
May 11, 2020Aspirant
Product Model: C7000v2 (high speed in only 1 device )
i have a Product Model: C7000v2 cable modem router Im using wifi in the house and I have 2 iPhones, 2 Ipads, 1 Windows laptop and 1 Apple laptop. Only 1 device (the apple laptop) works at 90 Mbp...
pablocarc
I dont know exactly. I only see one wifi network here, but doesn't specify if its 2.4 or 5 .
how I can tell ?
May 12, 2020Guru - Experienced User
You can log into the route and check which ssid (name) you have set for which band in the wireless settings.
here's how to get to the wireless settings and change them if needed
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
