webs2011
Sep 19, 2020Aspirant
Product to purchase
I have a cox panoramic wifi gateway (gigablast). I have both hardwired and wifi used in my house. I am looking at putting a firewall appliance that would be installed behind the gateway from cox, but would monitor/protect both my hardwired connections and wifi connections. I also have several TVs that utilize the cox wifi. Would like recommendations on products to purchase.
Thank you,
This a cable modem forum for NG only. Only discussion about cable modems and gateways made by NG are posted here.
I recommend you post over in the ISPs forum about there products and use of them.
IF your looking for firewall products, I would do a search online for firewall appliance devices.
Good Luck.
- webs2011Aspirant
Thank you.
