fieldro
May 30, 2018Tutor
ProSAFE Plus Configuration Utility for MAC
Hello,
I am trying to find out the IP of my switch. I need to access the menu to disable the IGMP snooping. The DHCP has given my switch another IP and the default one is not working.
Hav...
antinode
May 30, 2018Guru
> [...] The DHCP has given my switch another IP [...]
Then ask your (unspecified) DHCP server for a report on its clients,
and see if you can identify your "my switch" in that list.
Then, when you have a little time, you might give your "my switch" a
fixed IP address, so that you'll know where to find it without having
to do this search. That could be a static address (configured on your
"my switch"), or a reserved dynamic address (configured on your
(unspecified) DHCP server).
fieldro
Jun 29, 2018Tutor
am trying to discover the IP address using fing.
I have over 30 devices on my network and everything is just listed as generic.
Is there a Prosafe Configuration utility for the Mac? - would that be able to locate my netgear devices?
- antinodeJun 29, 2018Guru
Does that mean that you didn't "ask your (unspecified) DHCP server
for a report on its clients"?
> generic.
Is the MAC address of the switch printed on its product label?
All I know is what it says in the Installation Guide (visit
http://netgear.com/support , put in your model number, and look for
Documentation):
Note: The configuration utility is installed on your computer and
is only supported on Windows.
There are ways to run Windows on a Mac, but I'd be looking for a
simpler/cheaper way. For example, I might disconnect the switch, and
see which devices disappear. Then reconnect the switch (only, without
its attached devices), and see what appears. In some cases, a MAC
address can be tracked back to an equipment maker, using a Web sithe
like: https://macvendors.com/
Do you enjoy detective fiction?- fieldroJun 29, 2018Tutor
I have the MAC address for my Netgear. But fing is not able to show the MAC address of those identified as Generic - just says "not available"
> available"
I'll try again.
Still my advice.
