cuziamindian
Nov 25, 2024Aspirant
Ps5 cax80 lan issue
I keep my ps5 hard wired to router, never had any issues. Suddenly psn has errors connecting though I have full internet connection. Resetting router works temporarily. I have realized simply removing...
cuziamindian
My apologies for the mess, I'm not the most savvy, Thank you so much for the advice though! I'm def try checking the coax and swapping out if needed. That didn't even cross my mind. Already opened a ticket with Sony as well. I appreciate you, thanks again 🙏🏾
Nov 25, 2024Guru - Experienced User
Hopefully it will get resolved. Let us know.
One can take screen captures and post in a word application and save off as PDFs then attach to forum posts for best readability. 😉
- cuziamindianNov 27, 2024AspirantHey friend, just wanted to provide an update.
I did swap out the coax (old one looked just fine though) and it did not resolve the problem.
I did some random digging and learned that I don't need ports forwarded with upnp enabled, if working correctly (I think ). So I turned of upnp and kept the ports forwarded, no change. Then I enabled upnp and deleted all the forwarded ports, still no change and issue persisted.
I tried to use the multi gig port assuming I'd get slightly faster connection with my 1.2gbps internet, but that port had been the worse by far. No thumbnails would load in on the console at all, with the regular ethernet ports I still get some thumbnails. Also read that this port may be well be defective 🤷🏽, in many cases
Finally, last resort i just went through every setting i could find in my router page, and came across ethernet ports aggregation. Read up on it and thought i really shouldn't need this, but I enabled it anyways, let the modem do is thing and reset. Been working flawlessly since!!! All thumbnails load instantly, everything feels snappy on console interface again, nat type is correct and open on the games I need. Pretty stoked haha. It's only been couple hours so I'll have to see if this holds up.
Thanks again
Edit: reset ps5 connection to auto settings on lan settings, no more static ip. Did this first and there was no change. It's currently still auto but working fine with aggregate- FURRYe38Nov 27, 2024Guru - Experienced User
Hmmm, interesteing LAG seems to solve that though could be red herring or masking the real issue. Not sure how that would effect how the game console is connected. LAG feature would only be needed for LAG supporting devices. Otherwise should be disabled.
Yes, uPnP if enabled, PF configurations should not be configured.
Generally for most gaming, Sony and MS, no manual PF configurations are needed. Just uPnP handles everything.
Something to try later on, Factory reset and setup from scratch. Don't enabled anything, LAG or set any PF configurations. Don't enable Armor, Acess Controls, IPv6 or Traffic Meter. Leave uPnP default enabled. NAT should be good and connection should be good as well.
- cuziamindianNov 27, 2024AspirantI'll def give that a go as well! 🙏🏾🙏🏾🙏🏾
