cuziamindian
Nov 25, 2024Aspirant
Ps5 cax80 lan issue
I keep my ps5 hard wired to router, never had any issues. Suddenly psn has errors connecting though I have full internet connection. Resetting router works temporarily. I have realized simply removing...
Nov 27, 2024Guru - Experienced User
Hmmm, interesteing LAG seems to solve that though could be red herring or masking the real issue. Not sure how that would effect how the game console is connected. LAG feature would only be needed for LAG supporting devices. Otherwise should be disabled.
Yes, uPnP if enabled, PF configurations should not be configured.
Generally for most gaming, Sony and MS, no manual PF configurations are needed. Just uPnP handles everything.
Something to try later on, Factory reset and setup from scratch. Don't enabled anything, LAG or set any PF configurations. Don't enable Armor, Acess Controls, IPv6 or Traffic Meter. Leave uPnP default enabled. NAT should be good and connection should be good as well.
cuziamindian
Nov 27, 2024Aspirant
I'll def give that a go as well! 🙏🏾🙏🏾🙏🏾
