cailubx11's avatar
cailubx11
QOS Problem on Netgear cg3000dv2
now i dont know anything much about wifi configurations but it seems that my qos settings are disabled on my n450 (cg3000dv2) i have enabled my wifi multimedia and it says that i can configure my qos options there but theres no tab or links to edit my qos settings.
Are there any ways to enable it or anything to use it?
  • michaelkenward's avatar
    michaelkenward
    There is a manual for the cg3000dv2 somewhere at the end of this link:
    >> Click here >> N450 | Product | Support | NETGEAR << Click here <<
    Did you find the stuff on page 18?  The manual says that it provides "basic Quality of Service (QoS) features". Maybe that's as far as it goes.
    • cailubx11's avatar
      cailubx11
      Yes I have but are there ways to get it enabled.
        michaelkenward
        As I read it, make those settings and it will enable "basic" QoS for multimedia wifi.
