iopredman
Feb 06, 2020Initiate
Quality of Service settings do not save
Model: WNDR4500v2 Fireware: 1.0.0.72_1.0.45 OS: Windows 10 Pro Version 1909 Build 18363.592 Steps to repeat: 1. Log in to router. 2. Navigate to QoS setup via Advanced -> Setup -> QoS setu...
Feb 06, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
iopredman
I have done so. Thanks! I'll close this when either gets a reply.
- FURRYe38Feb 07, 2020Guru - Experienced User
:smileywink:
- mintrieriMay 27, 2020Aspirant
I may have the answer for you.
1. Go to the QoS settings
2. Edit the Device you want to change
3. ***Remove any spaces in the Device Name and Model Name
4. Hit Apply
My device and model name came up as "Playstation 4" by default with a space in the name. Changing them to "PS4" fixed my problem.
Hope that helps.
-mint
