1madmouse
Mar 25, 2023Star
question about downstream on CM1200 modem
I have a new CM1200 Nighthawk Multi-Gig Speed Modem and a X500 Nighthawk Gaming Router both have been working fine, but lately the second light on the CM1200 constantly blinks. We still have inter...
- Mar 29, 2023
You can pick them up off amazon for pretty reasonable. I'd snag at least a 6dbmv one. I recently bought a 3,6, 9 just to play with my signal levels on my modem at home for pretty cheap
Mar 26, 2023Guru - Experienced User
usually when its blinking its searching for channels.
do you have a screensnip of the cable connections page and event logs?
- 1madmouseMar 27, 2023Star
I will log into the modem and retrieve the logs. I have read some posts having the same problem, So i know what to look for. I have also rebooted the modem and 2 days later no blinking light but still seem to get the same type of logs. I will post back and go from there.
