eaglepi
Feb 03, 2020Guide
Question about reconnecting my network after moving. AC1750 Smart WiFi Router Model R6400
I have a question about reconnecting my network after moving. I am building a new house that is in the same city that I live now. I will be using the same ISP. When I move the router,modem to my...
antinode
Feb 03, 2020Guru
> [...] it should just boot up and run as if it was never moved,
> correct?
Sure, if the (unspecified) "same ISP" _service_ is the same. Why not
ask the (unspecified) "same ISP", to which you'll be complaining when
something goes wrong?
In a different location, the radio-interference situation might be
different, making a channel change beneficial.
Your external (public?) IP address might be different, and you might
care about that (or not).
As usual, many things are possible.
- eaglepiFeb 03, 2020Guide
thanks for your input
