eaglepi
Feb 03, 2020Guide
Question about reconnecting my network after moving. AC1750 Smart WiFi Router Model R6400
I have a question about reconnecting my network after moving. I am building a new house that is in the same city that I live now. I will be using the same ISP. When I move the router,modem to my...
antinode
Feb 03, 2020Guru
> [...] it should just boot up and run as if it was never moved,
> correct?
Sure, if the (unspecified) "same ISP" _service_ is the same. Why not
ask the (unspecified) "same ISP", to which you'll be complaining when
something goes wrong?
In a different location, the radio-interference situation might be
different, making a channel change beneficial.
Your external (public?) IP address might be different, and you might
care about that (or not).
As usual, many things are possible.
eaglepi
Feb 03, 2020Guide
thanks for your input
