Gp66
Jul 07, 2024Follower
Question about the power light on nighthawk modem
Purchased a Nighthawk modem CM2050V in Jan 2023 to replace a modem I had for 8 years. Yesterday the Wi-Fi went down and the power light was off. As I use the modem for phone service, the Tel 1 light...
Jul 07, 2024Guru - Experienced User
Others have posted that the LEDs on the 2000 series maybe fualty though the modem itself works. If the modem is still working, then run it as is.
Can try a different power adapter with same volts and amps to see if this changes anything.
