txyuan
Jun 30, 2021Aspirant
Question about WMM on C7000v2
I began to experience frequent disconnections during zoom meetings. When I ping 8.8.8.8 or 192.168.0.1, it shows frequent "timeout"(3%-9%). Some of the posts suggested to disable WMM, so I did. It so...
Jul 02, 2021Guru - Experienced User
Leave wmm on.
have you noticed if you're connected to the 2.4ghz or the 5ghz?
2.4ghz is slower and more sensitive to interference
- txyuanJul 02, 2021Aspirant
The same problem occurs, no matter I connect to 2.4 or 5GHz wifi.
Thanks.
- plemansJul 02, 2021Guru - Experienced User
does it happen hardwired?
have you tried changing mtu size?
Ping Test to determine Optimal MTU Size on Router | Answer | NETGEAR Support
How do I change the MTU size on my NETGEAR Wireless Router/DSL Gateway? | Answer | NETGEAR Support
