txyuan
Jun 30, 2021Aspirant
Question about WMM on C7000v2
I began to experience frequent disconnections during zoom meetings. When I ping 8.8.8.8 or 192.168.0.1, it shows frequent "timeout"(3%-9%). Some of the posts suggested to disable WMM, so I did. It so...
Jul 02, 2021Guru - Experienced User
Leave wmm on.
have you noticed if you're connected to the 2.4ghz or the 5ghz?
2.4ghz is slower and more sensitive to interference
txyuan
Jul 02, 2021Aspirant
The same problem occurs, no matter I connect to 2.4 or 5GHz wifi.
Thanks.
- plemansJul 02, 2021Guru - Experienced User
does it happen hardwired?
have you tried changing mtu size?
Ping Test to determine Optimal MTU Size on Router | Answer | NETGEAR Support
How do I change the MTU size on my NETGEAR Wireless Router/DSL Gateway? | Answer | NETGEAR Support
